error ipv4 multicast entry
  • Question
  • Updated 5 months ago
  • Answered
I open a GTAC case, I just put in this x440 stack (today first day of production) and I got the ipv4 multicast entry error any suggestions?
Photo of Karina Del Moral
Karina Del Moral
  • 804 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
The following GTAC knowledge article should fix your issues:
https://gtacknowledge.extremenetworks.com/articles/How_To/Multicast-Entry-not-Added-Hardware-Table-F...
Bill
Admin edit:  Fixed link
(Edited)
Karina Del Moral
  • 754 Points 500 badge 2x thumb
Thanks for your response Bill but the article is not available :(
The article referenced is currently unavailable
Photo of David Coglianese
David Coglianese, Embassador
  • 5,954 Points 5k badge 2x thumb
440s have very small tables and you are probably exceeding the limit. Can you post a snip of the log messages?
Karina Del Moral
12/28/2015 11:04:36.01 <Erro:HAL.IPv4Mc.GrpTblFull> Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
12/28/2015 10:04:15.69 <Erro:HAL.IPv4Mc.GrpTblFull> Slot-1: IPv4 multicast entry
Photo of Yusuf Kabbara
Yusuf Kabbara
  • 524 Points 500 badge 2x thumb
How does ...  <configure iproute reserved-entries> command change the amount of multicast entries? I didn't understand the command well!
Sorry... Here is the full article:
Procedure:
Option conserves usage of the hardware Layer 3 multicast forwarding table:
configure igmp snooping filters per-vlan
(to set it back to default set it to per-port)
After changing the IGMP snooping filters from per-port (default) to per-vlan you can disable IGMP snooping on VLAN's where IGMP snooping is not required:
disable igmp snooping vlan <vlan_name>
Stores multicast entries in the format (* AnySourceIP, GroupIP, VlanId), which is also referred to as (*, G):
configure igmp snooping forwarding-mode group-vlan
(to set it back to default configure it to source-group-vlan)
Routes with longer network masks might not be necessary if they are a subset of other routes with shorter network masks using the same gateway(s). When IP route compression is enabled, these unnecessary routes are not provided to the Forwarding information Base (FIB).
enable iproute compression
Additional notes:
Beginning in EXOS 15.4, the command configure igmp snooping forwarding-mode group-vlan was replaced with configure forwarding ipmc lookup-key group-vlan.
Hope it helps!
Bill
  • 6,204 Points 5k badge 2x thumb
This does work very well. I have not seen the error messages on any of our stacks after making the changes Bill suggests.
Either of the last commands here will fix your issue:
If pre 15.4 - "configure igmp snooping forwarding-mode group-vlan" and if 15.4 or later "configure forwarding ipmc lookup-key group-vlan"
Bill
Karina Del Moral
Thanks for your quick response, I enter the second one, (ver 15.7.1.4) and I'll monitor to see how it responds
Thanks
Karina Del Moral
Bill, so far, after applying the instruction, no log error since yesterday 12:04pm, thanks
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,784 Points 10k badge 2x thumb
To add a bit to it: EXOS stores, by default, multicast entries in HW as (S,G,V) in L3 Table resources, even if operating in L2. Your issue was typical of the x440 L3 scale, which is limited. What Bill gave you was a way to better optimize the L3 Multicast resources. IF you don't need L3, but only L2, and IF you still encounter your issue in the future, you may want to try switching to L2 learning for multicast. Scale will be way higher.
configure forwarding ipmc lookup-key mac-vlan
other options are: group-vlan (what Bill gave you), source-group-vlan (default) and mixed-mode
mixed-mode may be interesting if you have a mix of L3 and L2.
Karina Del Moral
Thanks for the information
Photo of Paul Poyant
Paul Poyant, Employee
  • 3,516 Points 3k badge 2x thumb
Sort of related to this,
I am working on new configs for a network refresh for one of our customers.
Code version: 15.7.2.9
Our current default multicast config for mixed networks (440/460) is:
enable igmp snooping forward-mcrouter-only vr VR-Default
The customer has distributed routing from the the building MDF closets I started working on some of the IDFs and the above config worked fine.
When I got to the MDF I found the current gear has:
enable ipmcforwarding vlan "ADDAMSD100"
enable ipmcforwarding vlan "RO_AES_HS_link"
enable ipmcforwarding vlan "RO_AES_SVR"
enable ipmcforwarding vlan "RO_AES_USR"
This does not work with in conjunction with our current default config. So I am trying to determine how to proceed. The MDF stacks are all 460s so they should be fine with the modifications to the table entries.
My concern is will things work with modified entries in the IDF and default entries in the MDF? Or should we use the default multicast table entry method everywhere and just deal with the error messages in the IDFs?
Thanks,
Karina Del Moral
The error appear again,
Slot-1 MDF-U-st.1 # sh log sev war
01/05/2016 14:14:07.07 <Erro:HAL.IPv4Mc.GrpTblFull> Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
01/05/2016 08:17:16.70 <Erro:HAL.IPv4Mc.GrpTblFull> Slot-1: Previous message repeated 3 additional times in the last 9511 second(s)
maybe last resort will be to put only L2, will this impact current traffic? do I need a maintenance window?
do you have any requirement or protocol needing L3 IPMC? This include PIM, MVR IGMPv3 and Private VLAN. If so, you'll need to turn on mixed-mode instead of mac-vlan as they cannot work in L2 mode. You should have a message saying that from the CLI.
The User Guide is a helpful resource for the details.
(Edited)
Did the switch reboot and possibly without the configuration being saved?  Assuming that is the case I would to refer to Stephane's post above and put it into L2 only, most likely based on your config as you have shared it most likely wont cause you any issue.
That command would be: "configure forwarding ipmc lookup-key mac-vlan"
(Edited)
You can check to make sure that the configuration is there by doing the command, "show config mcmgr" - It should show you the configuration that you are using assuming it is there.
Karina Del Moral
Thanks.. No reboot I check
Slot-1 MDF-U-st.2 # sh config "mcmgr"
# Module mcmgr configuration.
I would make the change as suggested to "configure forwarding ipmc lookup-key mac-vlan" and let it roll...
Couple of other commands to see the mcast cache...
"show mcast cache summary"
or
"show mcast cache" (will show you all)
  • 12,774 Points 10k badge 2x thumb
A command that is useful to check the current HW settings of a given platform (including ipmc lookup-key) is:
show forwarding config
Karina Del Moral
Thanks all for your feedback...
I have also another group of x440 switches, they are not in stack, are daisy chain, but I don't see that error on them... they are running an oldest xos version, 15.2.1.5  the stack 15.7.1.4.. so the warning error is due to the stack configuration? on the daisy chain I haven't apply any mcast configuration and the cache shows 24 entries on the stack around 46
Thanks
Karina Del Moral
And by the way... The Hub is the Best support group ever! :)
Karina Del Moral
Error still showing, not as much, I applied same rules in the MDF-u Stack of summit x440 and on the summit x440-24x, in the stack still showing, the only difference I see on the forwarding configuration is the hash recursion level
Slot-1 MDF-U-st.2 # sh forwarding configuration
L2 and L3 Forwarding table hash algorithm:
    Configured hash algorithm:              crc32
    Current hash algorithm:                 crc32
L3 Dual-Hash configuration:  (Applies to X460, X480, X650 and X670 only)
    Configured setting:                     on
    Current setting:                        on
    Dual-Hash Recursion Level:              3
Hash criteria for IP unicast traffic for L2 load sharing and ECMP route sharing
    Sharing criteria:                       L3_L4
IP multicast:
    Group Table Compression:                off
    Local Network Forwarding:               slow-path
    Lookup-Key:                             (*,GroupIP,VlanId)
External lookup tables:
    Configured Setting:                     l2-and-l3
    Current Setting:                        l2-and-l3
Internal lookup tables:
Switch Settings:
    Switching mode:                         store-and-forward
L2 Protocol:
    Fast convergence:                       on
Fabric Flow Control:
    Fabric Flow Control:                    auto
Slot-1 MDF-U-st.3 #
And this is the other switch (no error since yesterday after applied instructions)
mdf-24x-uplink.1 # sh forwarding configuration
    Current setting:                        on
    Dual-Hash Recursion Level:              1
IP multicast:
    Group Table Compression:                on
Switch Settings:
L2 Protocol:
mdf-24x-uplink.2 #
and the  mcmgr config information
Slot-1 MDF-U-st.3 # sh config "mcmgr"#
Slot-1 MDF-U-st.4 #
device no longer showing the error
mdf-24x-uplink.2 # sh confi "mcmgr"#
mdf-24x-uplink.3 #
The stack has ipmc compression turned off. The default is on and it should stay on, unless you are working around an issue that requires to turn it off.
If this is the result of a misconfiguration, please turn it back on, it will help a lot.
and, btw, you are still in group-vlan mode, not mixed-mode nor mac-vlan.
(Edited)
Karina Del Moral
Thanks,
I turn it back on, probably change it trying to fix the ipv4 multicast error
Karina Del Moral
It seems that after turning of the compression and with the instructions
no more ipv4 errors, almost 2 days,
 thanks
