Error setting port data for device
Luis_Mendes
Contributor
Error setting port data for device - When create any configuration on POLICY MANAGER, when apply this error appear with any model of device (D2,B5,C5)
2 REPLIES 2
Tom_Currier
Luis; There are several different methods for setting port data on a device and all should work as advertised. I've created a GTAC case in your name to follow up with this to identify the specific issue that you're running into and to get it resolved. I will email you directly via the case this morning.
Tom
Issue closed out through GTAC case
