ESVT does not run with Size Frame bigger than 1518 bytes
  • Question
  • Updated 1 year ago
  • Answered
  • (Edited)
Hello all,
I am using two X770, and I am testing the throughput using the ESVT tool.
For that test, I enable the jumbo frames in both switches, and create the test vlan to test a 40Gb link.
If I run the test with a Size Frame of 64 or 1518, it runs fine, and with no problems.
But, If I increment the size to another value more than 1518 it does not work.
Do you know if this is a limitation of the tool ESVT?
I also increase the ip-mtu size of the vlan to 9194, but with no success.
create vlan test40Gb tag 1040
configure vlan test40Gb add port 1:101 tagged
configure vlan test40Gb ipaddress 10.0.40.1/24 (and 10.0.40.2/24 in the other switch)
enable ipforwarding test40Gb
enable jumbo-frame ports all
configure ip-mtu 9194 "test40Gb"
run esvt traffic-test "test40Gb" loopback-port 1:97 peer-switch-ip 10.0.40.2 packet-size 9000 rate 40 Gbps duration 60 seconds
VLAN       Status   Loopback   Duration    Tx Rate   Tx Frame   Tx Total   Rx Total
                      Port    (hh:mm:ss)    (Kbps)     Size      Frames     Frames
test40Gb   Completed  1:97     00:01:00  40000000        64  3407020474 3407020474
test40Gb   Completed  1:97     00:01:00  40000000      1518   195051038  195051038
test40Gb   Error           1:97     00:01:00  40000000      9000           0          0
VLAN Name                      :  test40Gb
Port                                    :  1:101
IP Address                         :  10.0.40.2
Status                               :  Error
Duration (hh:mm:ss)          :  00:01:00
Loopback Port                   :  1:97
TX rate (Kbps)                   :  40000000
TX Frame Size (bytes)       :  9000
TX Frame                           :  0
RX Frame                           :  0
Frames Lost                        :  0
Error Cause                      :
<Erro:ESVT.TxPDUFail> Slot-1: Transmit PDU Failed from port 1:97; Reason[Failed to Send packet to loopback port]
Thanks for any suggestions.
Photo of Xperia Go
Xperia Go
  • 186 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,076 Points 5k badge 2x thumb
This is a known issue. This should get fixed but it's not currently scoped for any release.
https://gtacknowledge.extremenetworks...
(Edited)
Photo of Xperia Go
Xperia Go
Ok understood, thanks for the reply.
