Ethernet loopback test failed, is it a physical failure ?
  • Problem
  • Updated 4 years ago
  • Solved
Hi there,
I noticed that i have problem with ports on switch summit X450a-48t, it stops forwarding traffic randomly, so i did a show diagnostics : (is it a physical problem) ?
Slot-1: X450a-48tLast Test Date: Wed Nov 12 13:25:20 2014
Mac Loopback        : Run Test Failure on unit -[0], port-[8]
Loopback Phy Copper : Run Test Failure on unit -[0], port-[8]
Last Test Version:  12.4.2.17
Summary: Diagnostics Fail
Slot-2: X450a-48t
Last Test Date: Wed Nov 12 14:22:10 2014
No card in Slot-3
No card in Slot-4
No card in Slot-5
No card in Slot-6
No card in Slot-7
No card in Slot-8
Thanks & Regards
Photo of Asma DIB
Asma DIB
  • 70 Points
  • stressed
Posted 4 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,608 Points 10k badge 2x thumb
Official Response
I would suggest opening a case with GTAC. Most likely this is a hardware failure.
