esvt between X460 & X670
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
I was testing the esvt traffic-test in our Lab with a Summit X460 and a Summit X670 and ran in an issue XOS Version: XOS-16.1.2-Patch1-4:
When I run the test from the X460 to the X670 with a 10 G SFP (SR) and the rate of 10 Gbps on Port 49 the test does not start, and there is no error message at all
run esvt traffic-test v1 loopback-port 50 peer-switch-ip 10.1.1.7 packet-size 64 rate 10 Gbps duration 30 seconds
If I run the same test with 9 Gbps the test runs properly.
From the X670 to the X460 the 10 Gbps test runs perfectly without any Problems
Does this happen because I got not the same switch on both sides? Had someone a similar problem?
Photo of Mareen
Mareen
  • 364 Points 250 badge 2x thumb
Posted 2 years ago
Photo of David Coglianese
David Coglianese, Embassador
  • 6,264 Points 5k badge 2x thumb
Do you have an optic is port 50? We have not used the tool on a 670 but have run it on 460-G2 switches and found an optic needed to be inserted.
Photo of Mareen
Mareen
optic is inserted, i ran into that too :) after doing some tests
Photo of Drew C.
Drew C., Community Manager
  • 38,536 Points 20k badge 2x thumb
Mareen,
I believe you should open a case with GTAC for this.  Sounds like a bug.
Photo of Mareen
Mareen
Okay, thanks Drew, I will share the results here
