EWC: AP Accessibility Report does not show any values
  • 2
  • Question
  • Updated 1 year ago
  • Answered
What conditions must be set that the AP Accessibility Report show any data ?
(Something to active or some special AP familiy)
A lot of my installations shows there no values (only zeros) or only 0,x values.
What is the benefit of this report ??  In which szenario can help me this report ?
(Why does Extreme create this report ?)
Manual is very poorly - no answer there regarding this question!
http://documentation.extremenetworks.com/wireless/ug/wireless/user_guide/c_ap_accessibility_report.s...
GTAC KB also.
Hopefully some here can help me.
Regards
Photo of M.Nees
M.Nees, Embassador
  • 9,156 Points 5k badge 2x thumb
Posted 1 year ago
  • 2
Photo of Nathiya Munuswamy
Nathiya Munuswamy, Employee
  • 1,706 Points 1k badge 2x thumb
Hi Matthias,
Does this AP broadcasting any SSID? Is yes, is there any client connected to those AP's?
Regards,
Nathiya M
Photo of M.Nees
M.Nees, Embassador
this APs are working productive!
I check this report at several installations - all productive - same results (zeros or 0,x values).
Regards
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,286 Points 20k badge 2x thumb
Agree, something is off with the numbers.
Easy test, disass a bunch off clients on the same AP/radio.
I've done it with 4 clients and the counter peak current is .1 but it should be 4 in that case.
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,476 Points 5k badge 2x thumb
Matthias/Ron
I see the same behaviour in my lab, I will find out about this and let you know.
Regarding the documentation, please leave feedback there as well.
-Gareth
Photo of M.Nees
M.Nees, Embassador
Hi Gareth,
thanks for taking care.
For tracking this issue - GTAC Case: 01295841
Regards
Photo of M.Nees
M.Nees, Embassador
Documentation Feedback is given ...
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,110 Points 2k badge 2x thumb
FFI
you have the check this screen more often and chekc if really nothing shown.
But here more info's.
Q:
Why does the “cur” value for tx dissasoc show 0.13, should it not be 4 in 1 sec? Equally the peak should stay at 4 until 4 in a sec is exceeded? Similar can be seen in the other columns, Assoc req rx, reassoc req rx etc.
Can we have some details on how these numbers are calculated, I also noted there is a delay probably caused by the controller needing to receive data back from the AP that might skew these counters a bit more.
A:
The stats are collected as simple numbers of assoc, disassoc, etc. from the ap once every 30 seconds and calculated accordingly. The 4 disassoc in 1 sec becomes 4 disassocs in 30 sec which is the 0.13 disassoc/sec current value reported.
Also the algorithm for running average is:
Current average = 0.2 * current value + 0.8 * last average
Old values are overwritten since we are reporting a current and average value on a 30s cycle.
If nothing happanes after 30s it could we that we see only zero's.
Regards
Umut Aydin
