EWC C25 - Android Battery Drain
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
We have a 2x C25 Cluster that we upgraded from 7.41 to 9.21.05.0007-1. Since the upgrade we started to notice excessive battery drain on mobile devices, mainly Android devices.
Is there any problem reported regarding this issue?
I saw that there is a new version 9.21.06.0006-1, is it advisable to upgrade?
Thank you!
Photo of Tiago Moreira
Tiago Moreira
  • 190 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Joseph Burnsworth
Joseph Burnsworth
  • 2,328 Points 2k badge 2x thumb
We had the same issue in our office. The upgrade helped, however, in our situation we found that there was vlans tagged that werent needed on the switch ports for the AP and mDNS was hammering it. So, reconfiguring our ports and upgrading fixed ours
Photo of shashank sharma
shashank sharma
  • 222 Points 100 badge 2x thumb
no, i did the same thing but faced no issue like this
Photo of FES
FES
  • 1,360 Points 1k badge 2x thumb
we had the same problem and adjusted the minimun power and other params... Changes improved consumption.
Did you change anything to solve the problem?
Tiago Moreira
Hi Francisco,
I hadn't changed anything in config atm...I only upgraded to the latest version and we testing at the moment!
What other params have you changed?
