EWC C25 in LAN thru FW .. Ports??
  • Question
  • Updated 2 years ago
  • Doesn't Need an Answer
Hi every body ...!
I am having a problem with the EWC C25 ..
I configured a FW solution and now .. I have Ping to C25 and each AP and not problem .. From the C25 I have ping to APs too .. But .. The C25 don't see the APs Active ..
Do you know if I having this problem because any port is close ..? .. Please if you can help me ..
Thank you every one for your time .. And please .. Apologies for my English level .. Is not so good .. :(
Regards ...
Photo of Eivin Giraldo
Eivin Giraldo
  • 70 Points
Posted 2 years ago
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,114 Points 3k badge 2x thumb
Hi Elvin,
We require few ports to be opened between the Identifi controller and the APs.
Please click the following KB Article which lets you know the tcp/udp ports used between IdentiFi Wireless Controller and AP's:-
Photo of Salvador Gallo
Salvador Gallo
  • 452 Points 250 badge 2x thumb
Do you have a ipsec tunnels??
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 42,280 Points 20k badge 2x thumb
To better unterstand the situation we'd need the following....
- network diagram with IPs
- screenshot of the ping test so we'd see what you ping and the result
If you connect the AP could you see anything in the controller log.
Here a example how it should look like - the last message that you should see is the "blacklist sent"
So what do you see in the log?
Photo of Adilson Gal
Adilson Gal, Employee
  • 1,408 Points 1k badge 2x thumb
What do you mean by FW? If by FW you mean firewall, please refer to the "port list" portion (pages 32-34) of the release notes for a list of required ports that need to be open for a proper communication between the wireless controller (wc) and access points (ap) across a firewall.
