EWC ignore clients Deauth frames
M_Nees
Contributor III
At several customers EWC installations i am wondering that some clients are reported as active (Reports - All Active clients) although i know they are definitive offline.
To debug this i have connect a recent Windows 7 client to a WPA2 802.1x SSID. After that i disconnect the SSID via Windows normally.
Remote wireshark trace on that AP shows me a vaild Deauth frame:
But EWC report this MAC as active till idle timer after 30 minutes cut the session ...
Why does EWC ignore this above Deauth Frame ?
EWC = 10.31.07
Anybody who observe this behaviour too ?
11 REPLIES 11
Umut_Aydin
Hi all,
I will speak with Engineering about this and will raise a Feature Request if needed.
Regards
Umut Aydin
From my point of view this special, headstrong behaviour should changed to improve the product.
Especially the XMC and Control will benefit with better / more reliable visualizations of disconnected clients - currently we need 30 min (in default) to see if a client is disconnected.
Umut_Aydin
Hi all,
FYI
The de-auth packets removes the MU for the AP itself.
#cget muInfo wifi0/1
But it will remain in the client reports for the default idle timers.
After this time the MU get cleared in the Reports.
For more Info see please
https://gtacknowledge.extremenetworks.com/articles/Q_A/How-to-adjust-the-client-timers-on-the-Identi...
Regards
Umut
Adding some Flag into Client Report that MU is disassociated will be really helpful.
