EWC - V9.21.15 - AP3620 reboots unexpected (if users generate too much traffic )
  • 2
  • Question
  • Updated 1 year ago
  • Answered
My customer complains that a AP3620 reboot only based on the user load. Is this possible ??
I use EWC V9.21.15.
ap.log tell me that the regarding AP has bootet - but which trace file or log message tell me the reason for the last boot ?
Please help.
Regards
Photo of M.Nees
M.Nees, Embassador
  • 9,126 Points 5k badge 2x thumb
Posted 1 year ago
  • 2
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,152 Points 20k badge 2x thumb
I'd upgrade to v10, there are no known bugs in v10 for AP26xx and AP36xx.
Photo of M.Nees
M.Nees, Embassador
Good joke ....
Go to GUI > Logs > AP > Traces
Select the AP and click on retrieve traces.
If the controller is in a good mood that should download the AP trace file.
Open the .tar file and you'll find ap.logLastReboot.gz and one or more files with the name ap-report.txt*.gz.
Might be that you'd find the cause in this files or you'd need to open a ticket so the GTAC could take a look in the incl. dump.
BTW, does the > Logs > AP > Logs > Severity:All .... doesn't show the reboot cause ?
Photo of M.Nees
M.Nees, Embassador
You are right getting Trace Files from AP is not very reliable... i need 3 tries ...
unfortunately ap.logLastReboot.gz is corrupted but ap-report.txt tell me something:
Jan  1 00:00:52 kernel: kTrapMonitor: process cap is missing (fatal) -- reboot in [5+ sec]
As you see below is decide opening a case.
Regards,
Matthias
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,476 Points 5k badge 2x thumb
Hi Matthias
I would recommend you open a case to have the logs looked at.
-Gareth
Photo of M.Nees
M.Nees, Embassador
Case opened 01281431
Photo of M.Nees
M.Nees, Embassador
The problem is solved!
With the help of the excellent GTAC (thanks to Gareth) - we can find the root cause and solve the problem.
The Switchport was (historical) set to 100MBit and not to 1000MBit. Changing that solved the problem.
Regards,
Matthias
