exclude ip address from dhcp allocation range
  • 2
  • Question
  • Updated 3 years ago
  • Answered
Is there a way to exclude a range/single ip address from "configure vlan dhcp-address-range xxxx - xxxx"
for example: configure vlan vlan_name dhcp-address-range 10.1.1.20  - 10.1.1.254
Can I exclude 10.1.1.60 from being allocated?
Photo of Ionut Ciuperca
Ionut Ciuperca
  • 80 Points 75 badge 2x thumb
Posted 4 years ago
  • 2
Photo of Johan Hendrikx
Johan Hendrikx
  • 2,970 Points 2k badge 2x thumb
I have the same question
Photo of Andre K.
Andre K.
  • 356 Points 250 badge 2x thumb
I didn't ever work with EXOS, but I guess you are able to configure static DHCP reservations? If so, just reserve 10.1.1.60 for MAC address aa:11:22:33:bb:cc.
I admit it's a workaround but will prevent duplicate IPs.
Photo of Daniel Flouret
Daniel Flouret, Employee
  • 7,470 Points 5k badge 2x thumb
Ionut,
No, that's not possible. The DHCP server supports only a single continuous range of IP addresses.
The DHCP server implementation was originally meant to provide temporary short-lived IP addresses for Web-based network login, where the final IP address would be provided by a central company-wide DHCP server when the port was moved to the final VLAN.
