EXOS Alternative of CISCO's VTP & IP Route adding method Required
  • Question
  • Updated 6 months ago
  • Answered
I have to configure 14 access switches and 1 core switch for a customer, I am from Cisco background and want to learn VTP & IP route adding configurations. I got familiar on EXOS with aaa, DHCP and basic vlan configurations. I want to connect all 14 switches with 1 core switch, implementing VTP so that VLAN creation on core switch may create VLAN on all switches just like VTP. Also I want to know route adding configuration details as well.
Photo of Aneeq Zia
Aneeq Zia
  • 240 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,304 Points 10k badge 2x thumb
Hi Aneeq,
EXOS does not support VTP. It does support MVRP, but this requires at least two edge ports to be added to the VLAN first. Then MVRP will dynamically create the VLAN across the network. See the following GTAC Knowledge article for more information:
https://gtacknowledge.extremenetworks.com/articles/Solution/VLAN-not-propagating-across-the-network-...
As for adding static routes in EXOS, see the GTAC Knowledge article linked below:
 https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-and-delete-static-routes-in-...
Photo of Arjumand Qazi
Arjumand Qazi
  • 958 Points 500 badge 2x thumb
is MVRP the exact opposite of VTP?
VTP pushes vlan created on core  to edge switches in client server fashion. But in MVRP, vlans are advertised from edge to core.. is that how MVRP work ?
in summary its only to update the core with vlan information which is present on edge switches..
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,284 Points 10k badge 2x thumb
Yes, MVRP is client to client.
Photo of Aneeq Zia
Aneeq Zia
Thanks, perfect...
