EXOS edge port status logging
  • Question
  • Updated 2 years ago
  • Answered
Hello,
In EXOS, is there any way to disable the logging of port up/down events on edge ports?
Kind regards,
Frank
Photo of Frank Veen
Frank Veen
  • 492 Points 250 badge 2x thumb
  • happy
Posted 2 years ago
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,500 Points 3k badge 2x thumb
you can filter them from the defaultfilter
configure log filter defaultfilter add exclude events "vlan.msgs.portLinkstateDown" match port <portNum
Photo of Frank Veen
Frank Veen
Great, thank you!
It looks like there is a vlan.msgs.portlinkstate as well. that might be the better one to use, versus the Down identifier.
