EXOS packet handling - from vlan binding over policy/ACL handling to packet forwarding
  • Question
  • Updated 2 years ago
  • Doesn't Need an Answer
i am looking for some detailed information  how an EXOS Switch handle a data packet (beyond the manual).
In the old Enterasys knowledge-base i knew an article which described exactly what happenend when a packet is arriving on a port - how it is been forwarded - how VLAN and Policy is binding - Queue handling - etc. Is is the complete sequence. It was coming like a block diagram which shows all the details very clearly.
Unfortunately i cannot find the article again - but i knew it and i hope this informatione will be today also available for EXOS and EOS.
If somebody can provide such information it will be very welcome.
Regards,
Matthias
Photo of M.Nees
M.Nees, Embassador
  • 9,126 Points 5k badge 2x thumb
Posted 2 years ago
Photo of Edward Tsui
Edward Tsui, Employee
  • 602 Points 500 badge 2x thumb
Are you looking for this one? It can be found in user v16.2 user manual QoS section.
(Edited)
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Here's a link to the page Edward mentions:
http://documentation.extremenetworks.com/exos/EXOS_21_1/QoS/qos.shtml
I know Matthias knows this, but wanted to post for others that may read in future.
I'll ask around and see what happened to the old KB article he's referencing.
Photo of Paul Poyant
Paul Poyant, Employee
  • 3,516 Points 3k badge 2x thumb
Matthias, are you referring to Hub-based KB 5115, "Simplified Explanation of Routed Connection Setup for the DFE"?
The original source document was drafted in pre-Policy days (Jun 11 2003).
If this document is not a match, then a few more clues - such as product, era, or author - might help to focus the search.
That EOS document should provide a good baseline to evolve an EXOS-related discussion.
Thank you.
Photo of M.Nees
M.Nees, Embassador
yesterday i found this old document i am looking for !
Here it is:
Part 1:
Part 2:
Part 3:
Regards
(Edited)
That's KB 5252/ent15796, "General Explanation of How Switches Implement 802.1q VLANs", ported to the legacy KB as of Jan 02 2004 from an earlier article drafted outside the knowledgebase.
It has not been ported to the Hub or GTAC Knowledge.
Photo of M.Nees
M.Nees, Embassador
Hi All,
unfortunately both KB 5115 and KB 5252 do not answer my originally question.
These questions are:
+ How does a packet flows in EXOS - explained in the same deepth like KB 5252 does it for EOS
+ On EOS Policy VLAN Binding is always before static VLAN Binding !  Correct ?
  Regardsless if the policy is dynamic binded (RADIUS) or bind per admin profile (manual).
  Correct ?
  Same on EXOS ? Right ?
Regards
