EXOS: read via CLI / SNMP which air-flow is used in the switch
  • Question
  • Updated 2 years ago
  • Answered
it is possible to read out via CLI (remotely) which air-flow direction
(at the used fans) in switch is used ? Maybe the part-number of the fan unit.
Any advices.
Photo of M.Nees
M.Nees, Embassador
  • 9,126 Points 5k badge 2x thumb
Posted 2 years ago
Photo of Drew C.
Drew C., Community Manager
  • 37,322 Points 20k badge 2x thumb
I don't think so.  The only time I've seen it is when there's a mismatch, but even then I believe it doesn't give specifics.
You can, however, get the part number of the fan.
X460G2-24t-G4.2 # show fan detail
Slot-1 FanTray information:
State:                  Operational
NumFan:                 6
PartInfo:               1506N-4**** 800560-00-03
Revision:               3.0
Fan-1:                  Operational at 3180 RPM
Fan-2:                  Operational at 6960 RPM
Fan-3:                  Operational at 3180 RPM
Fan-4:                  Operational at 6780 RPM
Fan-5:                  Operational at 3180 RPM
Fan-6:                  Operational at 6840 RPM
This one happens to be a Front->Back airflow model.  What model(s) are you trying to look at?  I'll see if I can find the part numbers, if that will help.
-Drew
(Edited)
Photo of M.Nees
M.Nees, Embassador
Hi Drew,
thanks for your reply - you show me directly the issue!!
In your output the part-info of "show fan detail" is 800560-00.
If i have a look into the datasheet there exists 2 other partnumbers 10945 (front-to-back) and 10946 (back-to-front). Also in the pricelist are not the PartInfo number included.
Where can i see which PartInfo is which fan module ?
I am (and i think all the other community guys too) interested an all the summit fan part numbers - (especially X460-G2 / X670V / X670-G2 / X770 / X620).
Regards
Photo of Kevin Kim
Kevin Kim, Employee
  • 2,266 Points 2k badge 2x thumb
This is what I've got for X670-G1.
PSU: part number "800462" means FB. "800460" means BF.
FAN: part number "450300" means FB. "450326" means BF.
Photo of Drew C.
Here's what i could find for the reversible airflow models.  Let me know if I missed anything.
Fan Item#  Part #  Dir    Switch models
450300    17111   F->B   X670/V, X670-G2, X770
450326   17112   B->F   X670/V, X670-G2, X770
800560   10945   F->B   X460-G2, X450-G2
800561   10946   B->F   X460-G2
Don't forget that the PSU must match airflow as well.  I can look for those numbers if you'd like.
(Edited)
Photo of M.Nees
M.Nees, Embassador
Hi Drew (or anybody other) can you please update this list of fan and power supplies for the X450-G2 series !
Thanks.
Photo of Drew C.
Hi Matthias,
The X450-G2 series only supports F->B airflow.  All models use the same fan module as the X460-G2.
There are two PSUs available for the 450-G2 PoE models.  Non-PoE models use a fixed/built-in PSU.
10941 - Summit 1100W PoE AC PSU FB
10951 - Summit 715W AC PSU FB
