EXOS: setting Port quiet period for macauthentication
  • Question
  • Updated 12 months ago
  • Answered
On SecureStack switches i set on some customer projects the port quite period timer from 60 secs to a higher value.
set macauthentication portquietperiod time port-string
Unfortunately on current EXOS (16.1.x or 21.1 / 22.2.) there seems to be no command to do same setting.
Do i overlook something in CLI Reference?
Regards
Photo of M.Nees
M.Nees, Embassador
  • 9,414 Points 5k badge 2x thumb
Posted 1 year ago
Photo of M.Nees
M.Nees, Embassador
After some testing in my lab - i see that EXOS is working a little bit different then EOS.
EXOS does not authenticate a failed client endless based on a port quiet-period like EOS do.
So there is no demand for such a command.
Regards
Photo of M.Nees
M.Nees, Embassador
Current EXOS 22.3.1.4 do the endless re-Auth every 6 minutes if a System was rejected.
Command needed like set macauthentication portquietperiod time port-string
But it seems currently not available on EXOS :-(
Pending Case:  01380838
Regards
Photo of M.Nees
M.Nees, Embassador
Case is solved - EXOS can handle this!
MAC Auth can be controlled via "configure netlogin agingtime 60" which increases the default agetime of 5 minutes to 60 minutes.
802.1x can be controlled via "configure netlogin dot1x timers quietperiod 3600" which increases the default 8021.x quiet-period of 60 seconds to 60 minutes.
Thanks to GTAC for clarifying that.
(Edited)
