EXOS: Setting port speed and duplex via Netsight tools
  • Question
  • Updated 1 year ago
  • Answered
Whats is the suggested way if a customer wants to define port speed (maybe reduce gigabit switch ports to 100MBit because of bad cabling or other reasons) with graphical tools of netsight - like console or oneview.
My customer wants to do this on X440 (G1) and X440-G2 Switches with current 16.1.x. firmware. Netsight V7.0.
in oneview i do not find a way to do this ?!  Is this currently not possible ?
in Netsight Console (Properties - Ports) i can set the "speed admin" and "duplex admin" field and write it but the client anyway used gigabit speed.
Whats is going wrong here ?
Photo of M.Nees
M.Nees, Embassador
  • 9,168 Points 5k badge 2x thumb
Posted 1 year ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
Hi Matthias,
you need to disable auto-neg if you want to use the static speed/duplex values,
Cheers,
Ron
Photo of Curtis Parish
Curtis Parish
  • 3,332 Points 3k badge 2x thumb
Turn auto negotiation off.
Photo of M.Nees
M.Nees, Embassador
i want using auto-neg!
on EXOS i used the command: conf port X auto on speed 100 duplex full.
How can i do this setting graphically ??
Regards
If auto-neg is enabled then the other values are ignored.
So if you want to have 100/full disable auto-neg.
Photo of M.Nees
M.Nees, Embassador
I digging a little bit around but it seems that it  is currently not possible to reduce speed like needed above via graphic netsight tools ?!
A lot of my customer miss this feature !
@Ron: Please keep in mind if you disable Auto-Neg (set speed manually) on this port and the partner runs auto-neg you getting a lot of errors because of resulting duplex mismatch!
I think there is room for some enhancements!
Regards.
Matthias
