exos snmp oid to set port speed
  • Question
  • Updated 4 weeks ago
  • Answered
  • (Edited)
I want to change the port speed by SNMP. I have a X440 series switch with EXOS operating system. Can somebody tell which oid I need to use?
Thanks Roland Dal
Photo of Roland Dal
Roland Dal
  • 80 Points 75 badge 2x thumb
Posted 1 month ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 3,210 Points 3k badge 2x thumb
As per EXOS concepts guide, the OID (ifMauAutoNegAdminStatus) which is part of the ifMauAutoNegTable is mentioned as not supported for SNMP “SET” operations.
https://documentation.extremenetworks.com/exos_22.2/exos_21_1/configuration_management_enhancements/...
Photo of Roland Dal
Roland Dal
Ok that's clear.
Is there a Rest API (Perl / Python) available to manipulate the switch settings? If yes where can I found the information? (Sorry I am a new user)
Thanks for the help.
Roland Dal
Photo of Tomasz
Tomasz
  • 868 Points 500 badge 2x thumb
You can use SNMP manager (that is one of Extreme Management Center imminent features, or some standalone thing to modify MIB content on a device), or you can try CLI/TCL scripts (that will be put manually through SSH or via NMS software like XMC), or Python scripts (that can be put and executed on EXOS as a one shot or as a process), or JSONRPC, or (quite fresh - since 22.4) RESTCONF (kinda similar to NETCONF, there is YANG model etc.). You might find this useful: https://api.extremenetworks.com/
Regards,
Tomasz
(Edited)
