EXOS: use case for "port groups"
  • Question
  • Updated 9 months ago
  • Doesn't Need an Answer
Today i stumple about the following EXOS cli command:
create ports group port_group
CLI Reference mention this:
This command creates a generic port-group name that can be associated with a list of ports. The port_group option could be implemented in configure or show commands that currently accept a port_list.
Good Question: Which commands associate with a port_list ???
I do test on my EXOS Lab Switch (EXOS 22.2):
* TEST-SW.7 # configure ports "Uplink" ?
  add             Add ports to port group
  delete          Remove ports from port group
  rate-limit      Rate limiting
* TEST-SW.7 #
* TEST-SW.7 # sh port group "Uplink"
Group Name Ports
Uplink 49-52
* TEST-SW.8 #
I hope port group is a feature the does the same like "port range" at other vendors CLI... but i fear i am wrong.
How can i use port groups meaningful ?? What are the use cases for this command?
Photo of M.Nees
M.Nees, Embassador
  • 8,756 Points 5k badge 2x thumb
Posted 9 months ago
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,606 Points 10k badge 2x thumb
Hi Matthias,
my first thought is to use port groups as a more convenient port alias (or description). This might be helpful for show commands during troubleshooting. A name is easier to remember than the actual port list (ESXi_Servers vs. 3,7,9-12)
Just an idea,
Photo of M.Nees
M.Nees, Embassador
Hi Eric,
thanks for that explanation.
But it seem the implementation is bad or insufficient - see here:
* SW-KA.6 # show port "Uplink" ?
rate-limit Displays rate-limit discard statistics
* SW-KA.6 #
The only possible command is rate-limit - no other possible command.
Same try with a real port list:
* SW-KA.7 # sh port 49-52 ?
<cr> Execute the command
anomaly anomaly statistics
buffer Show packet buffering information
collisions Displays collision statistics
configuration Display the port configuration
congestion Display congestion statistics
debounce Display amount of time to delay link down detection
description Displays description associated with the port
eee Display EEE statistics
flow-control Displays pause frames received or transmitted
information Displays port information
ip-fix Displays IP Flow Information Export (IPFIX) statistics
no-refresh Page by page display without continuous refresh
packet histogram of packet statistics
protocol Protocol filter
qosmonitor QOS
refresh Continuous refresh of output
rxerrors receive error statistics
sharing Load sharing
statistics Port statistics
transceiver DDMI info
txerrors Displays transmit error statistics
utilization Port utilization information
vid VLANs in VID order
vlan VLAN
wred Display WRED statistics
| Filter the output of the command
* SW-KA.7 #
Where is the use case of this command ? What does developer and PLM want to address with this command ?
Photo of M.Nees
M.Nees, Embassador
Unfortunately yesterday i only have a look into CLI Reference - this does not help.
But EXOS User Guide helps:
Port groups allow the user to define ports by similar functionality or role. The user can create port
groups and use them to configure QoS profiles, ingress meters and flood rate-limiters for ports that
share the same role. In addition, Extreme Management Center will create and manipulate port groups
through the CoS MIB via SNMP.
This command sound to me to get another functionality - i mention the same usecase like eric.
But it does not - only qos, meters and rate-limits.
From my side this command have potential for upgrade ...
