EXOS XML-Notification vs NetSight webservice: Auth failure -> Lockout for webservices
LeoP1
Contributor
Hello Guys,
I have a customer migrating from EOS to EXOS, and we got several issues... We are working on Auth and Policy problems, but the XML-Notification (plus Identity Manager) are rising some alerts...
We configured the switches (X440-G2 22.2.1.5 patch1-4) like this:
# Module xmlc configuration.
# create xml-notification target netsight-target_172.18.1.50 url https://172.18.1.50:8443/axis/services/event vr VR-Default
configure xml-notification target netsight-target_172.18.1.50 user nsadmin encrypted-auth bnNhZG1pbjouIVNjaHVsekAyMDEzIzA3
configure xml-notification target netsight-target_172.18.1.50 from 172.18.7.241
enable xml-notification netsight-target_172.18.1.50
configure xml-notification target netsight-target_172.18.1.50 add idMgr
The password was typed as asked during the config (and triple-checked), but we are getting warnings on Console Log of Auth Failed and account lockout... There are several EXOS switches sending notifications to NetSight 7.1.2.12
The customer is running a Windows version of NetSight and the account isn't locked out on the OS.
Any ideas?
Best regards,
-Leo
2 REPLIES 2
LeoP1
Contributor
Hi Ryan,
This customer doesn't have NAC yet... We are using the GTACKnowledge solution (IDM+Netlogin) to show users in NetSight without NAC.
By the way, the XML-Notification doesn't work with any tested (by me) NetSight version when running EXOS 21.x... With the very same config, booting a 22.x it connects to Netsight instantly.
As stated in the GK posts and manuals, you need a OneView enabled user (with the according rights to login to the EMC).
Thanks for your support!
-Leo
Ryan_Yacobucci
Hello Leo,
When we setup XML notifications to NAC I believe we use the webservice credentials and not the NetSight user credentials.
Can you try with whatever webservice credentials are configured? By default they should be admin/Extreme@pp
Just a guess so cross your fingers.
Thanks
-Ryan
