Export Active Threats from Wireless Controller or OneView
  • Question
  • Updated 3 years ago
  • Answered
Hello all,
is there a way to export "Active Threats" reported from the radar functionality via script? In my opinion there are two opportunities. Either with the Controller or with OneView. In both system the active threats via GUI are available.
Any ideas?
Thank you for help.
Best regards
Stephan
Photo of Stephan Harrer
Stephan Harrer
  • 162 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
Hi Stephan,
do give the right answer the question is.. what are you trying to achieve.
It's "active threats" so it makes not much sense to export it i.e. once a day at midnight as you don't have the threats listed that were active i.e. at 9 in the morning.
-Ron
Stephan Harrer
Hello Ron,
here a little bit more information ;-).
We are responsible for the wireless service on a fairground. We are using Radar to detect foreign access points ( whose usage is forbidden). Therefor we need a list of foreign access points to talk to the user and motivate them to power off the access points.
To speed up the process I have to adjust the information shown in the controller or oneview report for threats and make it offline from oneview or the controller gui.
I want to export the threats ( only access points are relevant) all 30 minutes.
I hope that helps.
Stephan
Stephan Harrer
If there is no direct way to export the radar infos directly, the only way I see is to export the /var/log/syslog file from netsight and edit these file.
Not nice but it works
Stephan
