External Antenna for AP-7632-680B40-WR
  • Question
  • Updated 2 weeks ago
Can I use Extreme Networks Antennas with WiNG AP ́s?
I want to connect Access points in freezer environment. One option is to put the AP outside the cold chamber and the Antenna inside.
Years ago we use ML-2452-PTA3M3-036 with Motorola ́s AP. There is a better antenna to use with AP-7632?
Regards,
Photo of Pablo Moriconi
Pablo Moriconi
  • 180 Points 100 badge 2x thumb
Posted 2 weeks ago
Photo of Ron Galien
Ron Galien, Employee
  • 758 Points 500 badge 2x thumb
Hi Pablo, it would be best to review our Extreme Antenna Suite / Guide for listing of compatible antennas and coverage patterns. The AP7632 with external antenna connectionrs has RP-SMA female antenna connectors where the referenced antenna ML-2452-PTA3M3-036 has an RP-SMA male antenna connector for direct fit to this AP.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Where-can-I-find-the-Extreme-WiNG-antenna-gui...
Pablo Moriconi
RP-SMA female is the same on AP-650?
Photo of Ron Galien
That is correct. RP-SMA female antenna connectors on AP-650
Here is a picture of the RP-SMA female connector on the right and RP-SMA male connector on the left.
Pablo Moriconi
Ron,
So the documentation has errors?
Check this:
https://documentation.extremenetworks.com/WiNG/WLAN_Antennas/Antenna_Guide/WiNG_Hardware/Antenna_Gui...
In the doc, the RP-SMA Male is this one:
GraphicsRP_SMA_Mpng
Photo of Ron Galien
Thank you for bringing this to our attention. I will work with correct resources to get this information corrected. In the meantime - here is a good connector compilation which shows the correct antenna descriptions and gender:
Pablo Moriconi
OK, going back to the initial question, is the ML-2452-PTA3M3-036 the best option for the AP-7632?
I Will put it on the ceiling.
Regards,
Photo of Carlos Assunção
Carlos Assunção
  • 374 Points 250 badge 2x thumb
I recommend you to use ML-2452-PTA2M2-036
Carlos Assunção
The connector in the middle is for BLE and you can use the usual antenna
Pablo Moriconi
Thanks all of you for the recommendations
