External Antenna Product Photography?
  • Question
  • Updated 4 years ago
I have a project approved on spec and budget, but I have to get past an interior designer and imagery department.  Appearance and the ability to mask, hide, or make things "disappear" is very important to this client - more important that functionality in some aspects.  Are there photos or info sheets on the antennas?  I need to show them before they will sign off.
Photo of Dustin Willis
Dustin Willis
  • 80 Points 75 badge 2x thumb
  • frustrated.
Posted 4 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,914 Points 20k badge 2x thumb
Could you tell us which AP model you've planed for the installation as that would eliminate a lot of options.
Dustin Willis
Most indoor units will be 3825i so it's a non-issue, but there are a couple aesthetically sensitive areas where we may use the "e" version and try to stash the antennas.  Outdoor are all 3865.
