External Powersupply EPS500 and Summit X450
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Jun 28 2012 1:05AM
a customer told me, they tested the external powersupply, so they take off the power from the switch and they thought the eps500 take care for power. but the switch was going down. is there any configuration on xos to told the switch there is a eps500 connected? or should it do automatically?
thanks for help
(from Chris_HÃ1⁄4ttner)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Jun 28 2012 1:03PM
the switch will do it automatically when the EPS is connected into the port on the back. It will handle the switch if the primary goes down
You can do a show power to see the state of the power supplies
Thanks
P
(from Paul_Russo)
Create Date: Jun 28 2012 1:04PM
Can you please comment on which 450 they are connecting it up too?
P
(from Paul_Russo)
