Extremasys HiPath / Identifi C5210 Controller OID's for VNS traffic
  • Question
  • Updated 3 years ago
I am trying to collect trending statistics from our C5210 controllers for current traffic by VNS.
OneView will report the current VNS traffic or up to 24 days. I would like to query the current numbers and graph indepenently from the system.
Any Ideas or resources available?
Photo of E Beezy
E Beezy
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of McDonough, Michael
McDonough, Michael, Employee
  • 60 Points
You could start by taking a look at what the OneView system is polling.  Look under OneView-Administration->Diagnostics change the 'Level:Basic' to 'Level:Diagnostics'.  In the left-hand pane select Historical Statistic Collector->Statistics / Statistic Collection Targets.
That's going to give you a good idea as to what OIDs are being polled.  You'll end up (depending on what you're actually trying to trend) in iso.org.dod.internet.mgmt.mib-2.interfaces and iso.org.dod.internet.private.enterprises.siemens.hiPathWireless
If you're going to use Cacti you can probably find some templates floating around.
