extreme 450e booting problem
  • Problem
  • Updated 11 months ago
  • Solved
At the beginning it was a problem with my switch Fans
then Then the switch turned off
and i can't have an acces to my switch
i tried to booting the switch with this soltion
https://gtacknowledge.extremenetworks.com/articles/Solution/Summit-Boot-Up-Error-Messages-KICM-bcm-l...
 but without result
If I try to install EXOS (summitX-15.3.3.5.xos) from bootrom it failed with the following error :
download: The image you attempted to load is either not a  recovery image or it may be corrupted. Please try again.
Photo of ahmed Ahmed
ahmed Ahmed
  • 270 Points 250 badge 2x thumb
Posted 11 months ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
This is probably a hardware failure. I'd recommend opening up an RMA with GTAC.
ahmed Ahmed
but can we assert that this is a hardware failure :)
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,484 Points 10k badge 2x thumb
Ahmed,
Based on experience and the fact that you have already tried to reload EXOS through the bootrom we believe this is a hardware issue. You can try to get into the bootrom and type in "boot 3" to see if the diagnostic partition is still active. If that doesn't work then I confirm what Brandon said.
ahmed Ahmed
boot 3 doesn't work too
Photo of Ram
Ram, Employee
  • 1,450 Points 1k badge 2x thumb
Looks like a hardware failure. Unable to upgrade from BootROM. Raise a GTAC case to process an RMA
