Extreme 4950 switch UPnP support
Radcliffe_Barha
We recently upgraded from Avaya 4850's to Extreme 4950 switches. We are now having connectivity issues with our UPnP IP cameras after the upgrade. Are there any known issues with UPnP support for the 4950's?
3 REPLIES 3
Roger_Lapuh
Did your problem get resolved? If not, it would help if you described your problem in a bit more detail or even better open a case with support.
yves_weyns
what port speed do the camera's support?
what version are you running on the ERS 4950?
In the first versions there was a bug that 10/100 MBPS did not work. It was fixed in later releases.
Drew_C
Valued Contributor III
I wouldn't think a switch would have an effect on UPnP if normal IP connectivity is working as expected.
