Extreme AP Wifi security question
  • 2
  • Question
  • Updated 1 year ago
  • Answered
I am looking at all the various methods of Authentication and Encryption and am a bit confused after reading up about it. I havent seen anything saying how I can just set "WPA2-Personal" evel of security.
Can anyone point out which combo I should use to accomplish this?
Photo of Jacob Airov
Jacob Airov
  • 308 Points 250 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Christoph S.
Christoph S., Employee
  • 3,450 Points 3k badge 2x thumb
Hello Jacob,
Please advise model of AP and firmware version.
Regards
Jacob Airov
Sorry about that!
We're using AP7532, WiNG v5.8
Thank you.
Are these APs using Enterprise or Swift UI?
Jacob Airov
No clue what either of those things are.  These were purchased from Zebra before Extreme bought the company...
We have a VX9000 controller that they are connected to and controlled by.
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 2,056 Points 2k badge 2x thumb
For WPA2-Personal encryption, from the VX9000 UI, proceed to Wireless/Wireless LANs and add/edit WLAN. Proceed to Security and 'Select Authentication' should be PSK/NONE (WPA-Personal is encryption only). Scroll down to 'Select Encryption' and enable 'WPA2-CCMP' and under 'Key Settings', add the pre-shared key (passphrase). Once done, click on OK button then Commit/Save.
Jacob Airov
I knew the place in the UI, just didnt know the correct combo of authentication and encryption. Thank you.
So just so I have this straight-
At the top, the authentication section is only for using "WPA2-Enterprise", which is in connection to a RADIUS server
Then at the bottom, the encryption section is for other methods of security- WPA, WPA2, WEP (and all their current varieties)
Correct?
Hello Jacob,
From the "Select Authentication" option you can choose either personal (PSK / None) or Enterprise (EAP, etc..). Once you select PSK / None you scroll down to "Select Encryption" and in your case choose the WPA2-CCMP radio button. After you do this, the page will expand to allow you to add the Pre-shared key (passphase). At this point configure your pre-shared key and hit OK first, then commit and Save.
I hope this helps.
Thank you,
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,638 Points 5k badge 2x thumb
HI Jacob,
for deep understanding of this topic I'd recommend you to read CWSP book.
In short - WPA2-PSK (pre-shared key / personal) is always recommended choice unless you need to deploy Enterprise grade of security (WPA2-Enterprise)
By "unless you need" you can understand "AAA solution is available / required"
Regards,
Ondrej
