Extreme AP7502 firmware upgrading issue
Niyas
New Contributor III
I have Extreme access point AP7502, I have upgraded the firmware of AP to 5.9.1.0-029R. After upgrading firmware when I try to login AP through GUI showing error 404 not found.
7 REPLIES 7
Christopher_Fra
Upgrade using the standard image file, not the LEAN image. Also strongly advise to upgrade to a minimum of v5.9.1.5 to avoid known/resolved issues since v5.9.1.0. The latest/current firmware release for the AP7502 is v5.9.2.3 and should have v5.9.2.4 released early next week.
RobertZ
You need to upgrade your AP one more time via CLI using the non 'LEAN' image.
How To: How to upgrade WiNG AP firmware via CLI using FTP server
Andrew_Blomley
You have installed a LEAN image on the AP.
The LEAN image does not include a GUI to save space for other tasks such as storing Captive Portal pages.
The idea is as you are controlling the AP remotely, there is no requirement to have a local GUI.
if you require a Gui you can use the CLI command on the controller to load a new version of the AP7502 code
If you look at the ZIP file you will see both images
AP7502-LEAN-5.9.2.1-002R.img
AP7502--5.9.2.1-002R.img
if you use
device-upgrade command
device-upgrade load-image ap7502
URL Location of firmware image
URLs: tftp://[:port]/path/file
ftp://:@[:port]/path/file
sftp://:@[:port]>/path/file
http://[:port]/path/file
cf:/path/file
usb:/path/file
IPv6 URLs: tftp://[:port]/path/file
ftp:>@ sftp://:@[:port]>/path/file
on On AP/Controller or RF-Domain
or you can simply use the controller to control the AP as intended.
Please note all new version of controller code should install the LEAN image of the access point code for the above reason
This is different from the LEAN image of the controller which means that it does not include the AP images.
Niyas
New Contributor III
Please find the screenshot
6ba762b8fd194a47ad5e5ef562b5ee83_RackMultipart20181006-113267-scytsm-404_Error_inline.png
