Extreme Cloud - Fix zoom and location in "SITES - Tab"
  • Idea
  • Updated 7 months ago
  • Under Consideration
Hello,
in the SITES- Tab in the Extreme Cloud management there is a very nice map top of the window.
You can zoom and move the map like as you need.
But is there a way to fix the last zoom setting and position?
This function would be very helpful for example if you have some locations (=sites) in one town. You can move and zoom once to this town and fix it and you will see later always immediately the status of you sites in this town. If you can do this you have not always to move and zoom and every visit on this tab.
Best regards
Stephan Harrer
Photo of SH
SH
  • 4,174 Points 4k badge 2x thumb
Posted 7 months ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
I'll forward that request on to our ExtremeCloud Development Team.
Photo of SH
SH
Hello Doug,
thank you very much.
Best regards
Stephan
