Extreme Cloud initial connection to AP3805iFCC wireless access point - Item 30912
  • 2
  • Problem
  • Updated 2 months ago
  • Not a Problem
Someone please walk me through the initial setup of the AP3805iFCC Item 30912 using the extreme cloud.  The access Point shows when I log into the extreme cloud but when I click on the access point to configure it is show "undiscovered".  Can I connect with a laptop directly to the WAP to configure it?  DHCP?  Static IP? Crossover Cable?  Does the WAP have a default IP?  Any help would be appreciated.Thanks
Photo of Park Theater
Park Theater
  • 110 Points 100 badge 2x thumb
Posted 2 months ago
  • 2
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 19,730 Points 10k badge 2x thumb
Try to review the following article to see if it helps: https://gtacknowledge.extremenetworks.com/articles/How_To/How-To-Troubleshoot-ExtremeCloud
If you still have issues after, I would suggest contacting the GTAC for assistance: https://c.na29.visual.force.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Technical-Ass...
