Extreme Control Assessement Saint License expired
Patrick_Koppen
Contributor
If anyone uses assessement in Extreme Control with the internal agent-less scanner, the license is expired. All hosts pass the scan as 'black'. Control checks only for red and yellow,
so black is considered as green.
I had the same problem in 2016. See cases 01246055 and 01246057.
root@nac31:/usr/share/saint$ cat /usr/share/saint/saint.key
# BEGIN KEY
82XXXXXXXXXXXX
License: SAINT
License: singleIP
Expires: 8/31/2016
# END KEY
This time:
root@eace21:/usr/share/saint$ less saint.key
# BEGIN KEY
f5dXXXXXXXXXXX
License: SAINT
License: singleIP
Expires: 8/31/2018
# END KEY
XMC version 8.1 and 8.2.0.89
1 REPLY 1
Rodney_Lacroix
The license should have been updated with the late august update of the Saint files. If you're updating and maintaining the Saint assessment updates, this key should have been downloaded and modified prior to the expiration. The download of the updates can be automated, but the upgrade of the versions is a manual process.
That said, newer versions of NAC will have updated keys as part of the install/upgrade process.
