Extreme Management Center 8.0.2.42 Legacy Console Errors out starting.
  • Question
  • Updated 1 year ago
  • Answered
Extreme Management Center 8.0.2.42 Legacy Console Errors out starting. The User Connection Service is unavailable. Have already restarted the server.  This is an appliance so it is running some form of Linux.  Need to start this service, but I am not a Linux guy.  I am setting this up in my lab as I need to install for a client and just want to kick the tires first.  I have done many of the Windows installs with no issues.
Photo of Tim O'Donnell
Tim O'Donnell
  • 210 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Terry Rauk
Terry Rauk
  • 100 Points 100 badge 2x thumb
I have the same issue.
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,058 Points 5k badge 2x thumb
Hi Tim/Terry,
Did you get a chance to try out the steps in this article?
https://gtacknowledge.extremenetworks.com/articles/Solution/Java-client-does-not-launch-application-...
In addition make sure that a local firewall or security software is not blocking the connection.
Tim O'Donnell
No firewall issues.
As for the article I am going to inspect it closer tomorrow.  This was not an upgrade.  I am still going to see if any of the info is relevant though.  Thanks.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,154 Points 50k badge 2x thumb
what java version is used ?
Tim O'Donnell
Server JRE Version: 1.8.0_131
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,470 Points 5k badge 2x thumb
https://gtacknowledge.extremenetworks.com/articles/Solution/Common-Issues-Unable-to-connect-to-NetSi...
Specifically: NetSight Java error:
The User Connection Service in unavailable. You may need to restart your NetSight Server
Resolution: Remove the local C:/users/<user>/AppData/roaming/NetSight direction and delete the Java temporary files.
I run into this in my lab pretty frequently when jumping between versions of 8x and 7x. Usually just clearing Java temp files does the trick, but if not clear both the Java temp file and remove local NetSight files from the PC.
Thanks
-Ryan
