Extreme Management center and Fortigate integration guide?
  • Question
  • Updated 1 year ago
  • Answered
Any one have a guide in How to integrate the Extreme management center (connect) with the Fortigate?
Photo of Hossam Youssef
Hossam Youssef
  • 90 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Schmotter, Ryan
Schmotter, Ryan, Employee
  • 590 Points 500 badge 2x thumb
Hello Hossam,
I have the implementation guide for Connect 2.05, which is the latest guide I can find.
It includes instructions for the Fortigate integration.
You can download it from:
https://drive.google.com/file/d/0B5bMj99cONofd19hanpLdUpFQ1U/view?usp=sharing
Cheers,
Ryan
Photo of Ilya Semenov
Ilya Semenov
  • 4,590 Points 4k badge 2x thumb
Hello, Ryan,
Extreme Control is a required component?
Yes, in order to populate the End System database, you need EAC, which updates the Fortigate. However, if you have EXOS switches and Identity Management enabled, that may populate the ES database without the requirement for EAC, it just has not been tested and is not officially supported.
Ilya Semenov
Thank you.
I've tested the Identity Management with EXOS switches: it gives some information in CLI about IPs, hostnames and AD users for about 10-15% of switch ports. But the data could not be sent to Netsight.
(Edited)
