Extreme NCAP-500
  • Question
  • Updated 3 years ago
  • Answered
Does nayone knwo hwo to factory default these APs?
Thanks
Photo of JeremyClarkson
JeremyClarkson
  • 1,010 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Hernandez, Joshua
Hernandez, Joshua, Employee
  • 1,564 Points 1k badge 2x thumb
Jeremy,
If you have console access to the AP you can try the following:
At login prompt type: reset
At the Password prompt type: FactoryDefault
This may be SW specific.  From what I have researched there may be a reset button on the bottom but I do not believe it will reset.
