Extreme Networks with Virtual Device Context (VDC) ?
  • Question
  • Updated 3 years ago
  • Answered
In Cisco Nexus have a Virtual Device Context (VDC) for managing one physical switch to multiple logical switch.Could ExtremeNetworks do this function?
Thank you
Photo of PIYAPONG YWR
PIYAPONG YWR
  • 382 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Dorian Perry
Dorian Perry, Employee
  • 2,302 Points 2k badge 2x thumb
A similar concept in EXOS would be the use of a user created Virtual-Router (VR).
VR's have virtually separate routing and switching tables. Traffic by default is not routed or switched between VRs.
For additional details see the below section of the EXOS User Guide:
http://documentation.extremenetworks.com/exos/EXOS_21_1/Virtual_Routers/c_overview.shtml
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Hello,
Currently, if you have separate HW devices (let's say 2 BDX8s switches) you have to manage them individually.
There are some features that will help in some scenarios like MLAG, Virtual-Routers, etc. However you still need to configure each unit.
PIYAPONG YWR
Thank you for reply.
I understand that's VR can use in different tag vlan but I cannot adding same tag vlan in different VR, right?
From this concept, I have one physical chassis ethernet switch and I need to separate to multiple logical switch. for different kind of use.
Thank you for sharing
Photo of Henrique
Henrique, Employee
Vlan table is shared between VRs. However, each VR has its own L3 table and routing processes.
You can separate the switch to multiple local switch by creating different VRs and different L3 tables. However, you cannot use the same vlan for different VRs.
Each Vlan can belong to only one VR.
PIYAPONG YWR
Thank you, Henrique.
