extreme networks x440g2 -
tunfas
Please help me!
Hello. I tried to put in mgmt an static ip for this switch, but i never get a link. I remove ip from mgmt and i get ip from dhcp. Can someone help me how to solve this.
This is how i put the ip
#Configure vlan "mgmt" ipaddress xx.xx.xx.xx/23
#save
2 REPLIES 2
Drew_C
Valued Contributor III
I believe we solved this one in another thread: Problems with connectivity on VLAN mgmt
Mrxlazuardin
New Contributor III
Hi, Do you access management VLAN via dedicated managemant port? Management VLAN only connected to dedicated managemant port. Don't forget to put default gateway on management VR if you want to access it from different network. Best regards,
