Extreme Summit X-460- G2-24P Core switch configuration
  • Question
  • Updated 2 months ago
  • Answered
Hi, community. Good day, all. I am new with this product. I need your help for configuring an Extreme summit X-460- G2-24P core switch. Connecting to Edge switch (220 Series) with VLAN configs. Do you have advice or sample configs there for me to help.thank in advance?
Photo of Niyas
Niyas
  • 982 Points 500 badge 2x thumb
Posted 2 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,962 Points 20k badge 2x thumb
Photo of Niyas
Niyas
Hi Ronald,
Please find the below core switch configuration,Please check and verify the same
# Module devmgr configuration.
configure snmp sysContact "support@extremenetworks.com, +1 888 257 3000"
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-34
configure vr VR-Default add ports 1-34
configure vlan default delete ports 1-34
create vlan "Adminstaff"
configure vlan Adminstaff tag 33
create vlan "ap"
configure vlan ap tag 20
create vlan "Data"
configure vlan Data tag 18
create vlan "Guest"
configure vlan Guest tag 34
create vlan "Manag"
configure vlan Manag tag 14
create vlan "Students"
configure vlan Students tag 24
create vlan "Teachers"
configure vlan Teachers tag 22
create vlan "Voice"
configure vlan Voice tag 17
configure ports 29 auto off speed 10000 duplex full
configure ports 30 auto off speed 10000 duplex full
configure ports 31 auto off speed 10000 duplex full
configure ports 32 auto off speed 10000 duplex full
configure ports 33 auto off speed 10000 duplex full
configure ports 34 auto off speed 10000 duplex full
configure vlan Adminstaff add ports 25-34 tagged
configure vlan ap add ports 25-34 tagged
configure vlan Data add ports 25-34 tagged
configure vlan Guest add ports 25-34 tagged
configure vlan Manag add ports 1,25-34 untagged
configure vlan Students add ports 25-34 tagged
configure vlan Teachers add ports 25-34 tagged
configure vlan Voice add ports 25-34 tagged
configure vlan Manag ipaddress 10.4.4.1 255.255.252.0
enable ipforwarding vlan Manag
configure vlan Data ipaddress 10.4.8.1 255.255.248.0
enable ipforwarding vlan Data
configure vlan Voice ipaddress 10.4.17.1 255.255.255.0
enable ipforwarding vlan Voice
configure vlan ap ipaddress 10.4.20.1 255.255.255.0
enable ipforwarding vlan ap
configure vlan Teachers ipaddress 10.4.22.1 255.255.254.0
enable ipforwarding vlan Teachers
configure vlan Students ipaddress 10.4.24.1 255.255.248.0
enable ipforwarding vlan Students
configure vlan Adminstaff ipaddress 10.4.33.1 255.255.255.0
enable ipforwarding vlan Adminstaff
configure vlan Guest ipaddress 10.4.34.1 255.255.255.0
enable ipforwarding vlan Guest
# Module mcmgr configuration.
# Module fdb configuration.
# Module rtmgr configuration.
# Module policy configuration.
# Module aaa configuration.
# Module acl configuration.
# Module bfd configuration.
# Module cfgmgr configuration.
# Module dosprotect configuration.
# Module dot1ag configuration.
# Module eaps configuration.
# Module edp configuration.
# Module elrp configuration.
# Module ems configuration.
# Module epm configuration.
# Module erps configuration.
# Module esrp configuration.
# Module ethoam configuration.
# Module etmon configuration.
# Module exsshd configuration.
# Module hal configuration.
# Module idMgr configuration.
# Module ipSecurity configuration.
# Module ipfix configuration.
# Module lldp configuration.
# Module mrp configuration.
# Module msdp configuration.
# Module netLogin configuration.
# Module netTools configuration.
# Module ntp configuration.
# Module poe configuration.
# Module rip configuration.
# Module ripng configuration.
# Module snmpMaster configuration.
disable snmp access
# Module stp configuration.
# Module synce configuration.
# Module techSupport configuration.
enable tech-support collector
# Module telnetd configuration.
# Module tftpd configuration.
# Module thttpd configuration.
# Module twamp configuration.
# Module vmt configuration.
# Module vsm configuration.
X460G2-24p-10G4.2 # [B
Thank you
Niyas P
Sorry I don't want to be rude but that's not how this works.
I've no idea whether the config is good or bad because I don't know the network or what you'd like to accomplish with the config - there is no such thing as a core switch template that you just load and works for every customer on this planet.
It's your and my job to configure the hardware to the customers network requirements.
It's OK to ask a question to a specific feature/function/topic but IMHO it's the wrong place to get a step by step guide on how to configure a whole system.
As mentioned before you'd attend the product training for the system, pay a partner to do the work for you and learn during this process or just learn / play around using the user manual.
-Ron
Photo of David Coglianese
David Coglianese, Embassador
  • 7,138 Points 5k badge 2x thumb
Not rude at all
Photo of Niyas
Niyas
Hi David,
Please help me for configuring core switch
Thank you
Niyas P
What reseller did you buy your switches through?
What region are you in?
It really sounds like you need to work with a local partner to plan, design, and build your network.
I think all of us here are too responsible to simply give you lines to add to a config for a network we know nothing about. Not to mention the fact that many of us or our employers have paid for training. I'm sure someone on here could direct you to a class that you could take which would allow you to complete this config.
Photo of Niyas
Niyas
Ok Ron,Thanks for your support
