Extreme Summit x430 - 24t
  • Question
  • Updated 3 years ago
  • Answered
Hi! i Need some help, about the configuration Extreme SwItch Summit x430-24t . we need connect telephone cisco IP and i need the configuration.
Photo of Soc Activenetwork
Soc Activenetwork
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Mrxlazuardin
  • 1,454 Points 1k badge 2x thumb
Can you be more specific about connecting Cisco IP Phone? Maybe I can help you.
Best regards,
Soc Activenetwork
I have to connect a Cisco Ip Phone to Switch Summit x430-24t, we network have 2 VLAN (Data and Voice). and we need is a some configuration.
Photo of Alexandr P
Alexandr P, Embassador
  • 11,632 Points 10k badge 2x thumb
This task loooks like:
I have a pan and I want to wright. How can I do this?
What exactly configuration do you need?
Soc Activenetwork
we have 2 vlan data and voice, we have to configure in a single interface for voice and data , this point comes to an IP phone and IP phone to the computer.
Please help.
Tenemos 2 vlan de datos y de voz, queremos configurarla en un a sola interfaz para voz y datos, que este punto llegue a un telefono IP y del telefono Ip a el computador.
Ayuda por favor
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,050 Points 10k badge 2x thumb
Not sure what you are looking for.
The jumpstart guide shall help you: http://learn.extremenetworks.com/rs/extreme/images/Extreme-Networks-Deployment-Jumpstart.pdf
If you are in the default config, I would suggest to start by removing all the ports to the default vlan
# config vlan default del ports all
To create the two vlans, assuming they are named data and voice, with 802.1q tag 10 and 20:
# create vlan data tag 10
# create vlan voice tag 20
Add the port you need into it. Let's assume the port is port 1 and is untagged in vlan data and tagged in vlan voice:
# config vlan data add port 1
# config vlan voice add port 1 tag
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,016 Points 5k badge 2x thumb
In addition to the above from Stephane, here is document that we also have to discuss TLV's with LLDP , etc. that might be of some help.
