extreme summit x440 ping from management port to tftpd server issue
  • Question
  • Updated 2 months ago
  • Answered
I forgot the admin password for extreme summit x440-48t-10g.
In order to factory reset i have tried this:
config none is not working for me
from console port I have entered bootrom by pressing space bar.
I could set ip address and as a gateway i set ip of tftpd server but im unable to ping tftpd server
Here in the community i read that ip setting and pinging needs to be done from management port. When I switch console cable from console port to management port it is hanging.
Please guide me how to use management port in order to download image and factory reset summit x440?
Photo of Nurlan Turganaliev
Nurlan Turganaliev
  • 72 Points
Posted 2 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
The management port is a Ethernet port = just switching from console port to mgmt port doesn't work > you need to switch the other end of the cable (connected to the PC) from the serial port to the PC Ethernet port as well.
Also for it to work the mgmt port needs a IP address or you are not able to telnet/ssh to the port.
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Hi Nurlan,
Here's an article on this topic: https://extremeportal.force.com/ExtrArticleDetail?n=000002419
You can also follow this article for the reinstall: https://extremeportal.force.com/ExtrArticleDetail?n=000001620
-Drew
(Edited)
