extreme switch connected to cisco switch and losing packet
  • Problem
  • Updated 1 year ago
  • Solved
  • (Edited)
Hi All
Can someone help me, I have 2 ExtremeXOS  440 switches  version 21.1.1.4 connected to cisco switch 6500.
Problem : when I’ doing continues ping I’m getting packet loss and when one switch responding to my pings another will not respond vice vasa .
This is my configuration on extreme switches
create vlan "internal-man-105"
configure vlan internal-man-105 tag 105
configure vlan internal-man-105 add ports 2:24 tagged
configure vlan internal-man-105 ipaddress 1.1.1.1 255.255.255.248
enable ipforwarding vlan internal-man-105
configure ports 2:24 auto on speed 1000 duplex full
this is my configuration on cisco switch
interface GigabitEthernet3
 description Extreme-switch Uplink
 switchport
 switchport mode trunk
 logging event link-status
 logging event trunk-status
 logging event bundle-status
 logging event spanning-tree status
 logging event subif-link-status
 load-interval 30
 keepalive 30
 speed 1000
 duplex full
 udld port aggressive
 mls qos trust cos
 flowcontrol receive on
 flowcontrol send on
 spanning-tree portfast edge trunk
 spanning-tree bpduguard enable
end
Photo of Siva
Siva
  • 710 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hello Siva,
What switch are you pinging and where are you pinging from? What are the IP addresses of each switch?
Photo of Siva
Siva
Hi Patrick
My extreme switch IP address are 10.1.1.2 / 24 and 10.1.1.3 / 24 default gateway 10.1.1.1 /24
Cisco switch 10.1.1.1/24
 i'm pinging extreme switch from my laptop cmd
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,404 Points 2k badge 2x thumb
ip on your laptop is on the same subnet?
Photo of Patrick Koppen
Patrick Koppen
  • 750 Points 500 badge 2x thumb
Hi Siva,
on EXOS you turned auto-negotiation on and advertise only 1000/full.
Are you sure duplex full and speed 1000 does not turn auto-negotiation off on cisco?
Spanningtree or udld could be a problem. You should look at the error counters, fdb,
spanningtree, link state, ..... Turn on logging on IOS and EXOS. Does any happen?
Link los, errors disable, duplicate ip, arp change, TCN, ...?
show ip int brief
show interface
show controllers GigabitEthernet3
Regards
Patrick
Photo of Siva
Siva
Hi Patrick
I have check Spanningtree on cisco log i dont see and any errors so i believe Spanningtree is not an issue problem .
* Slot-2 Stack.1 # configure ports 2:24 auto off speed 1000 duplex full Error: Auto negotiation off is not supported on copper medium of combo port 2:24 at 1G or 10G speed.
when I try to make it off i'm getting above error
How to configure speed on EXOS not to be auto ?
(Edited)
Patrick Koppen
I hope not. Gigabit should always use auto negotiation. Try speed auto on Cisco.
An please check the error counters. Without a picture of you network and a detailed
error description it's just fishing in the dark.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,782 Points 10k badge 2x thumb
speed 1000 on Cisco IOS uses auto-negotiation, speed 100 disables it
Nick Yakimenko
any speed command on cisco disables auto-negotiation
to re-enable auto-negotiation you should issue
no speed
under selected interface
Hi Nick,
"speed 1000" on Cisco IOS does not disable auto-negotiation, it just restricts the advertised speeds to gigabit only. This is a trap I have seen many people fall into when trying to interconnect non-Cisco and Cisco switches with a "fixed" speed of 1000.
Thanks,
Erik
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,514 Points 5k badge 2x thumb
Siva,
Are the two switches(10.1.1.2,10.1.1.3) are in stacking?
If so can you post the "show switch" output from both the switches?
Patrick Koppen
Hi Siva,
error counters look normal (pause is strange...). Could you tell us a little more about you problem?
  • What is the IP of your laptop?
  • Which port is you laptop connected to?
  • What are the exact timings of the packet losses (e.g. loss after every 30 seconds, or work for 10 seconds, stopps for 60 seconds....)?
But still... it could be anything...
Regards
Patrick
as per the port number 2:24 it looks like a stacking switch to me but anyways can you share the "show switch" output from both the switches ?
Photo of Siva
Siva
Maybe I need to plug 2 switches on the different blade on cisco switch, I will do this tomorrow.
Siva,
Is it possible to share the "show switch" output from both the switches ?
Photo of Siva
Siva
I have to change the cable's and change ports on both Cisco switch and extreme switch but still experiencing the same issue.
At this stage, I think extreme switch are not the good one. :-(
Hi Siva,
Can you share the "show switch" output from both the switches please?
The last one you posted was "show conf" i am looking for the "show switch" output from both the switches and see what MAC address they have....
Hi Siva,
I guess during configuration you may have configured the same MAC address for both the stacks which is causing this issue.
please use the below command so that the MAC address will get configured automatically.
"configure stacking mac-address"
Please note that you need to reboot the stack once the command is executed.
I hope you will not see the reported issue once you do the above.
Hi Siva,
If i understood correctly although the switches have stacking enabled they do not have any physical connections via the stacking cable to any other node (switch).
If yes then the given command will only change the MAC address.
do you use a fiber connection between the Extreme and Cisco switches? If so, activating UDLD on the Cisco is problematic, because it is a Cisco proprietary feature that does not work with other vendors' switches.
Using Ethernet flow control (active on the Cisco) is not a good idea in general, it might cause intermittent problems, like dropping one ping packet or the other.
The "keepalive 30" setting on the Cisco is dubious as well, as this should enable a Cisco proprietary keepalive mechanism, but the EXOS switch does not send responses.
Since you have configured BPDU Guard on the Cisco, you must not enable STP on the EXOS switch. You can check if BPDU Guard error disabled an interface using "show interfaces err-disable."
Thanks,
Erik
Nick Yakimenko
they resolved issue
they had the switches stacking enabled but they did not have any physical connections via the stacking cable to any other node
they used the below command so that the MAC address will get configured automatically.
Photo of Drew C.
Drew C., Community Manager
  • 37,350 Points 20k badge 2x thumb
It looks like Siva has deleted most of their responses here. I'm going to mark this one solved and close the thread for further comment to prevent confusion.
