Extreme switch disconnects frequently from ODL controller
  • Problem
  • Updated 1 year ago
  • Solved
Hi, I'm using this switch X460G2-48p-10G4 (Stack) with openflow mode enabled and connected to my opendaylight controller as "primary":
Controller       : Primary
    Status       : ACTIVE
    Datapath ID  : 00000204969ac040
    VR           : VR-Default
    Mode         : out-of-band Active
    Target       : tcp:172.20.0.40:6633
    Uptime(secs) : 845
It happens very often that the tcp connection to the controller is being closed and reopened multiple times.
Is there any known issue on the switch?
Any useful diagnostic I can enable on the switch?
The log is not saying anything useful.
thank you
Leonardo
Photo of Leonardo
Leonardo
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,058 Points 5k badge 2x thumb
Leonardo,
To start with. did you get any insight form the "show log" , you can check the port where the controller is connected for any congestion, errors or flaps.
"show ports <port # >congestion"
"show ports <port#> rxerrors"
"show ports <port#> txerrors"
Also check for any issues in the counter part if none is found then i would suggest to open up case case with TAC.
Photo of Leonardo
Leonardo
I cannot find anything interesting in the log files, no mention to openflow disconnection events. From ODL side, I can see the following exception:
2017-07-13 04:38:50,495 | WARN  | entLoopGroup-5-6 | OFFrameDecoder                   | 265 - org.opendaylight.openflowjava.openflow-protocol-impl - 0.8.4.SNAPSHOT | Unexpected exception from downstream.
io.netty.channel.unix.Errors$NativeIoException: syscall:read(..) failed: Connection reset by peer
        at io.netty.channel.unix.FileDescriptor.readAddress(..)(Unknown Source)
2017-07-13 04:38:50,496 | WARN  | entLoopGroup-5-6 | OFFrameDecoder                   | 265 - org.opendaylight.openflowjava.openflow-protocol-impl - 0.8.4.SNAPSHOT | Closing connection.
2017-07-13 04:38:50,496 | INFO  | entLoopGroup-5-6 | SystemNotificationsListenerImpl  | 274 - org.opendaylight.openflowplugin.impl - 0.3.4.SNAPSHOT | ConnectionEvent: Connection closed by device, Device:/172.20.0.19:58045, NodeId:openflow:19706488169
According to the above log, it seems the device is closing the connection.
Every since the switch is sending a OFPT_ECHO_REQUEST message and the controller is quickly answering with OFPT_ECHO_REPLY. After this message exchange, the connection goes down.
Any thoughts?
thank you
Leonardo
Leonardo,
I would suggest to open up a case with TAC.
