extreme switch sending multicast messages (igmpv2 membership query general) without any request from device
  • Question
  • Updated 2 years ago
  • Answered
i am using extreme switch X460-24
I have vlan 174 configured with an ip pool which switch provides via dhcp
[config]
create vlan "vlan174"
configure vlan vlan174 tag 174
configure vlan vlan174 add ports 21-24 tagged
configure vlan vlan174 ipaddress 172.16.174.1 255.255.255.0
enable ipforwarding vlan vlan174
configure vlan vlan174 dhcp-address-range 172.16.174.2 - 172.16.174.200
configure vlan vlan174 dhcp-options default-gateway 172.16.174.1
configure vlan vlan174 dhcp-options dns-server 196.1.105.47
enable dhcp ports 21-24 vlan vlan174
[/config]
Why is switch sending multicast messages without being asked by any device ?
I can give wireshark log if required.
Thanks.
Photo of sumeet
sumeet
  • 798 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Kawawa
Kawawa, GTAC
  • 3,292 Points 3k badge 2x thumb
If I am not mistaken, this is consistent with RFC2236, When a router is in the "No members present" state, it still sends out a general query to to find out what multicast groups would be of interests to any attached systems. If the general query timer expires and no response has been received from any host, it resets it and sends out the general query again.  In EXOS the query internal is 125 seconds, and you can increase.
Photo of sumeet
sumeet
ok
how do I increase that interval ?
Photo of Kawawa
Kawawa, GTAC
configure igmp <query_interval>
The range is 1 to 214,748,364 seconds.
Photo of sumeet
sumeet
will try .
tell here , how it goes .
