Extreme VSS and NFS (CISCO)
  • Question
  • Updated 3 years ago
  • Answered
Hello guys,
I would like to connect two switches stack and configure they like a NFS or VSS like cisco devices, to provide more redundancy if one member fail all traffic, RIB, mac-table and so on will be forwarded to another member, its possible do it with extreme switch?
Photo of Tavares Belmont
Tavares Belmont
  • 638 Points 500 badge 2x thumb
  • Curious
Posted 3 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,016 Points 5k badge 2x thumb
Tavares,
You can stack up to 8 XOS switches.  This allows for a master/backup and all traffic can/will be forwarded in case of failure.  You can find more information in the XOS Users guide here: http://documentation.extremenetworks.com/exos/EXOS_All/Stacking/configuring-stacked-switches.shtml
Bill
Tavares Belmont
Thank you Bill,
But its possible manage two independent and diferents stacks? My costumer have two stacks separately look the pic pls.
Tavares,
You cannot configure two stacks together, they would be two separate control/data planes.  We do have a solution called MLAG that would allow for the same solution but the configuration is separate, the details are here: http://documentation.extremenetworks.com/exos/EXOS_All/Slots_and_Ports/c_blackdiamond-x8-series-swit...
Take a look...
Bill
Tavares Belmont
:D
Thanks i ́ll.
Tavares Belmont
Bill,
I found this document talk about VSB on page 17, http://learn.extremenetworks.com/rs/extreme/images/Data-Center-Design-Guide.pdf
its the same to configure vss?
Tavares,
Yes VSB (Very similar to VSS) can be done with S Series (EOS Operating System) and MLAG is done with XOS (Legacy purple products..).
Bill
Tavares Belmont
Hum i see, however my costumer decided to manage two stacks switchs as if they were just a one... If i configure MLAG i cant do it correct?
Tavares,
MLAG would let you take the two stacks and they would act as one, but you have to configure as two separate switches.
Bill
Tavares Belmont
OK, I got it,
But let's say if I want to configure a vlan on one of the equipment, the configuration is replicated to the other switch stack automatcally?
If you enable MVRP where the VLAN can dynamically create and tear down (similar to GVRP). So the answer is yes you can automate the configuration either with that or with some minimal scripting or using Netsight management.
Photo of An-Tin Liu
An-Tin Liu
  • 478 Points 250 badge 2x thumb
VSB is a good solution, one config one IP ,i have 3 customer they choice VSB to depoly thier network.   the distance with two core is 250M.
