Extreme Wireless Controller Splash Page - No Redirrection Problem
  • 2
  • Problem
  • Updated 11 months ago
  • Solved
Dear All,
I have encountered a problem with configuration of splash page. I have made two roles, before and after registration. Unfortunately in unregistered role controller does not redirect the traffic. When I type an address of my splash page in web there is only something like this (Below) but i cannot accept anything so there is no connection to the internet.
My rules on the controller looks like this:
172.16.4.10 is the address of my splash page on the controller. Is there something wrong with these rules?
Photo of Grzegorz Niemiec
Grzegorz Niemiec
  • 294 Points 250 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,846 Points 20k badge 2x thumb
You'd need to deny traffic or there is no redirect to the portal,
And to test it you surf a webpage i.e. www.extremenetworks.com and not use the IP of the portal.
Here a example - it's guest portal instead of splash but beside that option the config would be the same....
https://community.extremenetworks.com/extreme/topics/how-to-identifi-wireless-appliances-guest-porta...
-Ron
Grzegorz Niemiec
Thank you for answers, but I have tried both guides with this same effect. Also I have tried both methods of blocking the traffic (from policy rules and from access control in VLAN&Class Of Service window) same effect. No redirection when I trying to connect to any portal through domain address or IP address. Only direct splash portal address works, but there is an index window, no accept (login page/policy).
Host WiFi card information:
Photo of Doug Hyde
DNS is resolving correctly? If that's the case I would contact the GTAC so someone can take a look at all your settings. This should work as it's a standard function with our controllers.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
I think the role isn"t correct - here a example of mine, the 172.24.25.253 is the IP of the controller/portal in the guest topology so replace it with your controller/portal/topology IP.
Add the other rules exactly like below, the in/out is very important so make sure it's configured as below.
Photo of Doug Hyde
Grzegorz,
Were you able to get this working?
Thanks,
Doug
Grzegorz Niemiec
Thank you all for help. The problem laid in:
https://gtacknowledge.extremenetworks.com/articles/Solution/Clients-are-not-redirected-to-the-Guest-...
Here are politics which worked for me:
