Extreme Wireless vs HParuba selling point required
  • Idea
  • Updated 1 year ago
Hi Team,
This is muthu I am the extreme wireless engineer I need selling point Extreme wireless.
Extreme Vs Hp Aruba
Regards
N.Muthu
Photo of muthu naganathan
muthu naganathan
  • 202 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
What Aruba version you would compare? The instant version have big problems with the captive portal. It's very limited.
WiNG have a big plus for global installation and perfect options for remote packet capture.
BR
Timo
muthu naganathan
Aruba IAP version vs Extreme (wings)  required only for wireless.
Photo of Peter Chang
Peter Chang
  • 394 Points 250 badge 2x thumb
Well, we used to be on Aruba for 7-8 years. We got rid of it because support was horrendous. We recently made the switch to Extreme Wireless, and we couldn't have been more happier with the switch. GTAC Support has been great so far as well!
Regards,
PC
muthu naganathan
Hi sir,
I am looking for technology  wise comparison which is available in extreme wireless and which is not in Aruba IAP.
Regards
N.Muthu
muthu naganathan
Hi sir,
How to push  Extreme  wireless in Aruba account.
Regards
N.Muthu
Photo of Timo
Timo
Captive portal is very powerful compared to Aruba.
Remote debug functions are very powerful with the WiNG and not possible with Aruba.
This are the two best functions compared to aruba. The VC from Aruba Instant is better at the time. I wasn't use the VC from WiNG, use a VX9000.
For configuration WiNG provide more options, if you know what you'll do. Aruba and a lot other vendors are limited in the options.
Best regards
Timo
muthu naganathan
Thanks very much ....
Photo of Rajesh Jeevendran
Rajesh Jeevendran, Employee
  • 354 Points 250 badge 2x thumb
Hi
The equivalent of  Aruba Instant AP is Wing Express AP, not the wing AP ?
Was the above discussed in that perspective ?
Please correct me if I am wrong.
Regards
Rajesh J
Photo of Timo
Timo
from the feature set I wouldn't use the Express one. Mostly this solution have enough features, but you can't extend it. The Instant APs have maybe comparable features, but you can extend it with AirWave or a controller and a firmware update. This is with the Express not possible.
Best regards,
Timo
