Extreme WS-AP3715i Can't be Detected by WS-C25 Wireless Controller.
  • Problem
  • Updated 2 years ago
  • Solved
The AP was configured before to be used for demo(DHCP). Tried hard reset many times on the AP but still no go. I dunno the IP address to try SSH. Any other way to reset the AP so it could discover the controller?
Photo of Ronaldo Asimao
Ronaldo Asimao
  • 330 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Photo of Rajesh Jeevendran
Rajesh Jeevendran, Employee
  • 354 Points 250 badge 2x thumb
Hi Ronaldo
Thanks for raising this post.
To Factory reset.
Try console [serial] in the Access Point,set the speed[baud] = 115200
username:admin
password:new2day
cset factory
reboot
Also i would like to know the below
Software version on the C25 controller.
Does the other AP models and other AP3715i work fine on the same controller.
Regards
Rajesh J
Ronaldo Asimao
Yes, both the AP and the controller worked together during the demo. We will be having another demo on a different potential client, so we configured the controller with a different IP, after that we connected the AP and reset many times using the pin reset or whatever is called.
Hi Ronaldo
Thanks for your response
If the AP still fails to grab the IP via DHCP. Consider the below from AP console
Login to AP, type following command:
cset dhcpc disable
cset ipaddr x.x.x.x ( IP Address of the AP)
cset ipmask x.x.x.x
cset authip 1 x.x.x.x            #HWC esa port IP address
or this it depends on AP Type
set authipaddrs 1 x.x.x.x
(You can check this if you ask for the AP config via # cget c g)
capply
csave
reboot
Regards
Rajesh J
Ronaldo Asimao
hi. Does Extreme has a some sort of proprietary DB9 to RJ45 connector? Because I tried to use the one from Cisco and I can't console to the AP.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,380 Points 20k badge 2x thumb
Nope, that cable works 100% even it's from Cisco :-)
Have you set the baud rate to 115200 ?
Hi
Please set the below
Regards
Rajesh
Ronaldo Asimao
Hi. that is the settings that I used when trying to console to the AP but still won't let me console to it. Serial cable is working on Cisco devices. Anyway, i tried hard resetting the AP again, and now the AP and controller see each other.
I just find it weird that i did hard reset the AP many times last week but it don't see the controller, not it worked. I did not do any config changes.
