Extreme x620-16t Inventory manager archive error "Connection Refused" CLI access is not enabled
  • Problem
  • Updated 1 year ago
  • Solved
I have 2 x620-16t switches that my coworker has setup.  The 2nd switch was setup using the config from the first one and had the IP changed so the config should be the same.  However, I am not able to get the archive working in EMC/Inventory Mgr.  It gives the error "Connection refused, CLI access is not enabled for this device".  I got the first one working but this one will not.  How to I enable this when all settings that I know of are or should be the same as the first switch?
Photo of Phillip Hood
Phillip Hood
  • 352 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,484 Points 10k badge 2x thumb
Hello Phillip,
Do you have any configuration on either switch in relation to an access profile or any type of security configuration?
Phillip Hood
Are you talking about the SNMP profile?  They are both set to the same as all other switches.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
Check in EMC if both are set to the same profile in device mapping (lower part of the screen) ...
Phillip Hood
They are the same.
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,474 Points 5k badge 2x thumb
If you use SSH, do you have the key generated? What is the "show management" output from both? Any difference there?
Disable and enable ssh ?
Anything in the switch log?
Phillip Hood
Firmware Rev 1.0.1.7, Software Rev 21.1.1.4
  • 11,474 Points 10k badge 2x thumb
What is the patch?
Phillip Hood
Patch 1-2
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Remove the switch and re-add it.  If that's possible...
Phillip Hood
Well, it turns out that there was a bug for SSH in the firmware version that came on the switches.  The latest that came out on February 1st is supposed to fix it and I will be applying that to both switches today and retesting.
