extreme x670 1/g sfp port not active
  • Question
  • Updated 3 years ago
  • Answered
hi guys im new to extreme switches and im having a hard time configuring these switches
heres the scenario:
we have extreme x670v switches and using 1/g sfp tranceiver
configure vlan "public" add ports 17-24 untagged
enable ports 17-24
now to check if the ports and vlan are working:
laptop 1 connected to port 17 with same subnet
laptop 2 connected to port 24 with same subnet
both ends unreacheable
and when i enter this command
show vlan, it says no active ports
am i missing something here?
show vlan "public" VLAN Interface with name public created by user
        Admin State:    Enabled         Tagging:        802.1Q Tag 99
        Description:    None
        Virtual router: VR-Default
        IPv4 Forwarding: Disabled
        IPv6 Forwarding: Disabled
        IPv6:           None
        STPD:           None
        Protocol:       Match all unfiltered protocols
        Loopback:       Disabled
        NetLogin:       Disabled
        QosProfile:     None configured
        Egress Rate Limit Designated Port: None configured
        Flood Rate Limit QosProfile:       None configured
        Ports:   8.       (Number of active ports=0)
           Untag:      17,     18,     19,     20,     21,     22,     23,
                       24
        Flags:    (*) Active, (!) Disabled, (g) Load Sharing port
                  (b) Port blocked on the vlan, (m) Mac-Based port
                  (a) Egress traffic allowed for NetLogin
                  (u) Egress traffic unallowed for NetLogin
                  (t) Translate VLAN tag for Private-VLAN
                  (s) Private-VLAN System Port, (L) Loopback port
                  (x) VMAN Tag Translated port
                 (G) Multi-switch LAG Group port
Photo of Ariez Dres Ahito
Ariez Dres Ahito
  • 140 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Senguttuvan, Arun
Senguttuvan, Arun, Employee
  • 876 Points 500 badge 2x thumb
Hi Ariez,
Based on the show vlan output, as you said none of the ports are active. Could you check the "show ports 17-24 configuration" output after connecting the laptop to the ports.
I would also like to know if the SFP used is BASE-T? Could you check the LED status of the switch port?
Ariez Dres Ahito
Port Configuration Monitor                              Mon Nov 16 07:11:15 2015
Port      Virtual          Port      Link  Auto    Speed         Duplex     Flow   Load     Media
              router         State   State  Neg   Cfg Actua l Cfg Actual   Cntrl  Master Pri Red
17       VR-Default       E        R      ON        1000          FULL                           BASET
18       VR-Default       E        R      ON        1000          FULL                           BASET
19       VR-Default       E        R      ON        1000          FULL                           BASET
20       VR-Default       E        R      ON        1000          FULL                           BASET
21       VR-Default       E        R      ON        1000          FULL                           BASET
22       VR-Default       E        R      ON        1000          FULL                           BASET
23       VR-Default       E        R      ON        1000          FULL                           BASET
24       VR-Default       E        R      ON        1000          FULL                           BASET
i man using extreme sfp model: 10070h 10/100/1000base-t sfp
thaks the prompt reply
Could you share the show switch output to understand the flavor of switch being used. Also, provide the output of "debug hal show optic-info ports <port#>".
Ariez Dres Ahito
SysName:          X670V-48x
SysLocation:
SysContact:       support@extremenetworks.com, +1 888 257 3000
 System MAC:       00:04:96:99:A6:F7
System Type:      X670V-48x
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
  System Watchdog:  Enabled
Current Time:     Mon Nov 16 08:41:50 2015
Timezone:         [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
 Boot Time:        Mon Nov 16 03:29:25 2015
 Boot Count:       7
Next Reboot:      None scheduled
System UpTime:    5 hours 12 minutes 25 seconds
Current State:    OPERATIONAL
Image Selected:   primary
Image Booted:     primary
Primary ver:      15.1.2.12
Secondary ver:    15.1.2.12
Config Selected:  secondary.cfg
Config Booted:    secondary.cfg
 secondary.cfg     Created by ExtremeXOS version 15.1.2.12
 369510 bytes saved on Fri Nov 13 05:14:20 2015
debug hal show optic-info port 17
 Port             17
Status           Enabled
AutoNeg          ON
Speed            1G
 Duplex           FULL
  Auto Polarity    0
  GBIC Type        BASET
   GBIC Vendor      FINISAR CORP.
   Part Number      FCLF8522P2BTL-EX
  Serial Number    PTB05GF
  Extreme Appr     EXTREME0TRateI  "
   Gecomp           8
   Id               3
   bitRate          C
  bitRateMax       0        bitRateMin       0
  en9u1000m       0
    len9u100m        0
(Edited)
Ariez Dres Ahito
ill try to update it to latest firmware 16.1.2
then i will update you guys.. thanks
Photo of David Coglianese
David Coglianese, Embassador
  • 6,294 Points 5k badge 2x thumb
Did you give the laptops ip addresses on the same subnet as the vlan?
If you are using dhcp is boot p configured and enabled?
Ariez Dres Ahito
@david of course same subnet. and im not using DHCP laptops are configured static..
Ariez Dres Ahito
hi guys.. seems a firmware issue. i updated the firmware to latest version,  ports are active now.. thanks
