Extreme Networks Summit 400 48t switch
  • 2
  • Problem
  • Updated 3 years ago
  • Solved
It seems there is no way for me to get the latest firmware (7.8.4 I think?) from Extreme Networks for my Summit 400 48t switch becuase it is "End of Life".
Why can't Extreme Networks provide free firmware updates on their website with an easy registration/login process like many other companies? Instead I'm directed to a partner who won't talk me to because my product is at the end of its life cycle. This discourages me from purchasing anything from Extreme Networks or their partners in the future as there seems no easy way for customer self service.
Photo of mattk
mattk
  • 110 Points 100 badge 2x thumb
  • annoyed
Posted 4 years ago
  • 2
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
It's always depends upon what contract you have on device. If device is cover under partnerworkplus then you have to contact to partner else you can directly contact TAC and get the assistance.
Sumit Tokle, Alum
Upgrade a Summit 400-48t to ExtremeWare 7.4 as follows:
1 Upload the current configuration to a TFTP server.
2 Verify the current BootROM is version 5.1. If the BootROM is version 5.1, go to step 3, otherwise
download the BootROM: s400_boot51.bin and reboot the switch.
3 Download ExtremeWare 7.3 image.
4 Save the configuration using the save configuration command.
5 Download ExtremeWare 7.4 image.
6 Reboot the switch using the reboot command.
7 Download the configuration you saved in step 1. For example:
download config 10.60.112.254 saved.cfg
This step is optional.
You can download the requested software from this link:
http://www.extremenetworks.com/ftp/ftp_new.aspx?file=rvandijk/ASL Extreme Firmware request.rar
The rar files includes the following files:
v73e0b43.Cxtr
v742b6.Cxtr
ExtremeWare 7.4.2b6 Rev03 RelNote-1.pdf
Photo of mattk
mattk
Thanks Sumit, I appreciate your effort but that appears to be quite an old firmware release for the switch (7.4.2b6), even older than the one I'm currently running (7.7e.3.5). I believe the latest release for the switch is 7.8.4. Any possibility of getting this?
Sumit Tokle, Alum
https://www.dropbox.com/s/cyyh88tleh5n878/v784b1-patch1-4.Cxtr
Use above link to download 7.8. patch 1-3.
Photo of mattk
mattk
That worked great! Thank you so much.
Photo of Leif Pedersen
Leif Pedersen
  • 70 Points
Any chance to resurrect that link? I also need to upgrade a switch to 7.8, but can't find it. Thanks!
Photo of mattk
mattk
Try this <link removed by an admin>
(Edited)
Sumit Tokle, Alum
Hi Mattk,
Thanks for helping Leif.
Sumit
Leif Pedersen
  • 70 Points
Got it. Thanks!
Photo of Loren Robert Lisk
Loren Robert Lisk
  • 152 Points 100 badge 2x thumb
Anyone have the ability to link to the ssh enabled version of the firmware?
Photo of Vince
Vince
  • 60 Points
is there a way to get documentation for Summit 400 24t and 48t? I have inherited a server room with 3 of these switches and no docs.
Vince
Photo of Drew C.
Drew C., Community Manager
  • 40,070 Points 20k badge 2x thumb
Hi Vince,
Do you still need documentation for these switches?  If so, let me know which ExtremeWare version is on them and I'll get the files for you.
Photo of Outback Dingo
Outback Dingo
  • 60 Points
is there a 7.8 ssh version someplace, picked up 2 used 400-48t's and seriously have issues with telnet and web bieng enabled... but still need remote access
Loren Robert Lisk
Couldn't Find a ssh Version myself but would love one too
Outback Dingo email me at <email address removed by an admin> i got something you might like.
(Edited)
